Vacuums KLZE
Vacuums KLZE
solenoid that goes on the firewall. One vacuum goes near the throttle body and the other one goes to the charcoal canister(referring to vacuum diagram in the FAQ section) I see no place to put the vacuum on the charcoal canister... so im stuck with one vacuum that i dont know where to put. thanks. KLZE Curved neck
- Ryan
Re: Vacuums KLZE
that is the purge solenoid. there should be a vac nipple on the top of the charcoal canister. If not... just leave it, its not really a vital system, its emissions.
Re: Vacuums KLZE
You didn't find stuff like this in your search. Helps a lot. http://www.google.ca/search?hl=en&q=klz ... 0AG2yMHsDQ
Re: Vacuums KLZE
Checked them. Thing is, i cant find a vacuum hole ON the canister
- Ryan
Re: Vacuums KLZE
It should have three holes, one big one that leads back to the fuel tank area, a drain on the bottom, and a vac nipple.... if it broke off you should be able to see where it was
looking at other pictures online, it looks like the vac nipple may be on the bottom of it.
Re: Vacuums KLZE
Mmmmm, nipples,,,,,mmmmm
