So, i drove from kelowna to invermere the other day. The bumpy road messed up my right rear. I need all my bushing all around the replaced though. Even the strut caps. Aside from the caps, does anyone know any good priced polyurethane suspensions kits for V6 mx3's'??? Please post the links here. I'd'like to see what worked well for you guys.
I want to avoid napa auto parts.
my suspension is messed up! advice!!!
- mikeetown
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
- MrMazda92
Re: my suspension is messed up! advice!!!
Energy suspension or Wytbushings come to mind... Searching for either should yield good results, but Wytbushings will be harder to find.
- fowljesse
Yeah, the Energy Suspension write-up was done on my car. They work great! When I get into the corners, it feels like I'm drifting, because the passive all wheel steering becomes quite active.
- Josh
Surf through this for a bit and you can find many of what you need. http://www.clubprotege.com/forum/showth ... hings-list
- mikeetown
Thanks guys. I havnt had time to get on a computer lately so this will kickstart my search.
I like mooge parts but there arent kits for them. Only seperate peices
mikeetown
