Blinker question....
kulluminati777
Post by kulluminati777 »
So on american MX-3's the daytime running lights (blinkers) come on when u put on the head lights...is there anyway to lose this and still keep the blinker function or no......
Re: Blinker question....
I know the emergency brake switch kills them. It's located on the handle.
Evo_Spec
Post by Evo_Spec »
yes, there's 3 wires that go to that plug, one's the DRL, one's the blinker, and then ground. What you can do is just cut the DRL wire and that'll prevent it from turning on OR you can bring the DRL light over into the spot that JDM/EDM cars put it.
You can't really see clearly in the picture but if you compare to the daytime one i'm sure you know where i mean.
kulluminati777
what color wire is the drl brother
Evo_Spec
Post by Evo_Spec »
it should be the red one for the DRL's and i think its green or green/red but it has green and that's the blinkers and then black for ground
kulluminati777
cool thanks alot
