Its been 5 years since ive been on here, I have a ton of parts at my work that I had been collecting for my project.
I pretty much had the all the engine, fuel and ignition systems.
Off the top of my head without going back there and looking i have:
A dis assembled 97 Probe 2.5l.
ZE Heads (used)
Cant remember the name but the stronger valve springs.
Cams - 210degrees / 218degree, loeb sep 112degrees. These were made for me by Colt Cams were for a boosted 10.1 setup.
Diamond Racing - 10.1 Forged, ceramic coated and moly coated pistons (you get 9 of them) 1st Bulk buy Diamond sent 6 pistons for the front bank, they then sent me 3 more for the back bank.
Huge H beam connecting rods from some crazy hard aluminum w arp bolts.
Full set of ARP block and head studs specific for the 2.5l, last time i checked they still dont have a part number for these, a member worked there and had 10 sets done up custom.
Ford Racing ZX3 struts.
Dual Oil Filter relaction kit.
Mazda Speed Oil Catch Can.
Phenolic spacers (both DE and ZE kits)
SRD bushings, everykind he made, and his bronzoil.
PMO Slimline fans.
MSD 6btm Ignition
MSD Blaster Coil (used)
UR Underdrive pulley (used)
67mm Throttlebody done pro by PMO a long time ago.
Knock sensor
Timing b tensioner
Aeromotive FPR (which cen be setup for dual fuel) (Used)
OBD1 ECU from 94 Probe (used)
OBD2 ECU from 97 probe (used)
Full harness from 94 MX6 (used)
DE TB and elbow (used)
Autometer Air/Fuel (Pn 2675)
MSD RPM Module selector (used)
Stainless red clear coated brake lines
Stainless end links or sway bar links (2 new unused and 2 being used).
A fiberglass front bumper unpainted cant remember the type, not stock.
Im not looking to spend alot of time sending one thing here and one thing there, im looking for someone who is looking to start a project and wants to skip about a year of searching.
If someone is interested i will take a better inventory with pics.
I will sell at a loss, but will not give this stuff away.  Low ballers will be ignored. Almost everything is new un used.
						A ton of parts from my project that never happened.
- diezzel
Re: A ton of parts from my project that never happened.
Pmd for the throttle body and spacers.Thanks.
You need to post this with this prefix [FS] and you need to price this lot.  Forum rules.
Lots of nice stuff here so hurry and price this stuff. Cheers
- Ryan
Hey bud.  Nice list, what happened to your project?  It sounds like it would have been awesome.
I'm interested in the stuff I picked out below... forum rules are you need prices, so if you could, that would be nice.
Spinkx79 wrote:Its been 5 years since ive been on here, I have a ton of parts at my work that I had been collecting for my project.
- AaronTietje
Pm about the bushings
							We all want to be fast and look cool.  Cool changes but fast never does.
						- MrMazda92
I'm interested in the valve springs... Are they ferrea by any chance? JW. Also, which retainers did/do they come with?
- Evo_Spec
i'm also interested in the Mazdaspeed oil catch can
