KL31 cams in KLDE
eunosklde
KL31 cams in KLDE
Post by eunosklde »
Quick question,How much work is involved in installing KL31 cams in a 2002 KLDE.Is it a straight swap or does it need shim modification's etc.Im running a KLZE longneck and KL31 ecu and je50 on my klde.Thanx for any help crew :)
pattheriault
Re: KL31 cams in KLDE
Post by pattheriault »
no need for modification..
it's as simple as removing intake mani valve cover timing belt.. and swap the cam.
eunosklde
Post by eunosklde »
Thanx heaps pattheriault your a champ :)
