moon waxs
mccabe
moon waxs
Post by mccabe »
im looking to paint my new mx3 that i have just bought its a 93 gs se. ive looked for the topic but cant find it
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
MrMazda92
Re: moon waxs
Post by MrMazda92 »
Moon wax?
If you're referring to MoonEggs's Wax technique... It's called primer and no clear or base :freak:
Re: moon waxs
It's funny how legacies start... I guess this is mine... below is the process for MoonWax® (AKA Primer) :freak:
Wash car
First time using MoonWax® - wetsand with 400 grit
rinse off/wipe off residue
wetsand with 1000 grit
tape off windows, etc
spray rattle can black primer (I usually go around with 2 light coats)
let dry
wipe down with a damp cloth
dry sand with 2000 grit
wipe off dust with damp cloth
spray rattle can black primer (2 more light coats)
remove tape
done
Keep in mind that a true MoonWax® job really should be performed by Mooneggs himself. I've never seen another primer job that looked as good as mine. I have seen better flat black paint and vinyl wraps that looked better but I'm sure they cost more than $50 :D
MrMazda92
Re: moon waxs
Post by MrMazda92 »
Mooneggs wrote:It's funny how legacies start... I guess this is mine... below is the process for MoonWax® (AKA Primer) :freak:
Wash car
let dry
remove tape
done
I've read it elsewhere, but would like to see it again; How long between re-applications? You're tempting ME now...
MrMazda92
Re: moon waxs
Post by MrMazda92 »
Geeze, why'd you have to make it sound so easy? -.-
At this rate, I'll have to go up to Portland and have you show me how to do it. ;)
Cold beers are on me if you accept! :D
Dark_Rider2k3
Re: moon waxs
Post by Dark_Rider2k3 »
It's funny because I saw this car (not sure of what make/model it's been months) that had a Moon special and all I could think of was "... Moon did it better.."
mx-3_4evr
Re: moon waxs
Post by mx-3_4evr »
here is my flat black (primer spray can done last year,pics are recently) :D
Re: moon waxs
Post by wytbishop »
^^^mx-3_4evr has the best MX-3 engine bay IN THE WORLD^^^ seriously...the best, cleanest engine bay anywhere ever.
The primer looks tight too man. I am working on my own version of the Moonwax...sort of. I did the first test piece last night. I look forward to unveiling it soon. Just have to do a bit of body repair first.
DeadMaker
Re: moon waxs
Post by DeadMaker »
Ok this colour seems more grey than black same as mooneggs car..
It is the primer that can not go full black?
Hmm i am jealus :love:Maybe in the future i will paint my car with primer using air paint gun :D
Black Mazda Mx3 Rs 1997 B6DE
mikeinaus
Re: moon waxs
Post by mikeinaus »
DeadMaker wrote:Ok this colour seems more grey than black same as mooneggs car..
flat black looks a little grayer then the standard black. plus there using primer so it fades overtime.
RobMinhas
Re: moon waxs
Post by RobMinhas »
Has anyone successfully attempted this method with a different colour? I'm tempted, but I don't know if i want the flat black/grey colour. I'm gonna get my hands on a junker car and maybe try some different colours on different panels but I was wondering if anyones tried it yet.
mazda915
Re: moon waxs
Post by mazda915 »
dude oh man such a sexy flat black mx with the black rims man super awesome looks great better than mooneggs lol jk jk
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
mitmaks
Re: moon waxs
Post by mitmaks »
You can get any color to be flat. You add flattener to the clear coat and you'll have flat colored car with UV resistance of clear coat over the color.
MrMazda92
Re: moon waxs
Post by MrMazda92 »
mitmaks wrote:You can get any color to be flat. You add flattener to the clear coat and you'll have flat colored car with UV resistance of clear coat over the color.
That's awesome! Flat enough that minor door dings are still invisible?(or nearly so)
RobMinhas
Re: moon waxs
Post by RobMinhas »
That's great, I'm excited to see what colours will look good.
Return to “Appearance”
