Sam's 1.6 MX-3- LT Turbo project.
- AaronTietje
Re: UK Sam's 1.6 Turbo MX-3 project
So, what is the radiator out of that your using?
youdirtyfox
youdirtyfox
323 Turbo manifold >10 all prices are in £££
323 Turbo baffled sump >5
IHI VJ-11 Turbo >90
AEM F/IC ECU >280
Boomslang harness >130
wideband lambda > 130
SPEC clutch >200 +100 delivery
Injectors > 20
Boost pipes/joiners/silicon elbows > 30 - 80
smaller width radiator > 20
hose clips > 20
Intercooler > 10 - 100
Oil lines > 20
Water lines > 20
Boost guage > 30
Exhaust flexi > 20
sundries > 40
after studying the schematics and the AEM,
we have decided to make our own boomslang
harness, saving us £££
IHI VJ-11 Turbo >90
AEM F/IC ECU >280
Injectors > 20
hose clips > 20
Oil lines > 20
Water lines > 20
Boost guage > 30
Exhaust flexi > 20
sundries > 40
- AaronTietje
Cool you have a £££ button on your keyboard. All I have is a $$$.
youdirtyfox
but a mate realised I had the keyboard on USA settings
youdirtyfox
alright back on with the rad. install
Started making this today, wich is
going to be a header tank for the rad.
youdirtyfox
bit more work today!
just waiting on the filler neck
and she can be welded up and polished
- marcdh
mad skillz yo !
View Worklog
View Worklog
youdirtyfox
Cheers Bro! been working lathes now for coming upto 13 years now
Factory shutdown! so Im on Holiday now!!woop!!
Cant finish the tank now though
Needed to do a bit of sussing out anyways...
...thinking clear filler hose or see through green hose
would look quite mental.
12" slimline fan on order to make even more room!
you know just incase i want to go twin turbo,lol
Been checking out how straight I can get this boost
hose in there ( represented by the metal pole)
be back soon with full rad install.
youdirtyfox
Just a little light releif here from
the seriousness of the rad install..
... Mr sharp shooter is hookin up for a ride yo'all!
youdirtyfox
youdirtyfox
Ford Capri pressure cap.
cut tank down a bit to get the lower filler pipe higher
than the top rad. hose.
new stainless steel top rad. pipe.
youdirtyfox
youdirtyfox
one of the last bits I needed is here!
still got plenty more surprises for you good people
youdirtyfox
Top hose done! left long as I need 35-38mm silicone reducers each end.
Tank sealed and spanked up!
Cant wait to get this lot on da motor
