SeaFoam discovers Vac Leak
Ok, I Seafoamed my engine and after start up I noticed smoke from under the hood. Now I've had a couple of issues like stalling when stopping or if I take my foot off the gas pedal quickly. I checked under the hood in the area of the smoke only to find a bolt missing from the back of the intake where that U shaped pipe is bolted. I'll continue to check but if I hadn't of Seafoamed in preparation for a clean air inspection I never would of notice that bolt. Yah Seafoam
- mitmaks
Re: SeaFoam discovers Vac Leak
it must've washed away all that gunk that was sealing crack like gasket.
- mazda915
i love sea foam use it every 15k miles on gas engine and oil
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
Excuse me Sir, my engine has no g g gunk (I can hardly repeat it). I'm sure when the intake was installed someone didn't torque that bolt properly. Gunk, hmm, the nerve.mitmaks wrote:it must've washed away all that gunk that was sealing crack like gasket.
- WhiteFinish
Nice
Hopefully your engine runs smooth now.
Re: SeaFoam discovers Vac Leak,,,almost?
I went over and checked on my spare ZE, (we all have spare ZE's don't we
) anyway the bolt was missing on that engine as well so I guess that intake cross over tube part is only held together with one bolt at each end. Strange, now I have to trouble shoot where the leak is. If anyone knows where to buy those little place line plugs please let me know. I want to replace all the plugs on my engine.
- _-Night-Shade-_
There's only 1 bolt because that tube has o-rings.
I'm going to check those little black rubber condoms and then the VRIS for leaks.
