harness??
- Ryan
Re: harness??
Search, FAQ's.
Its literally all there, there's even a post describing the differences between the harnesses.
Re: harness??
Ryan, I bought my bp and well I've been reading but can't find hard now I figured my problem I have a 2nd gen bp and need to buy one since I cantt use my sohc do u knowif I can use a escort gt
							92 RS- (2nd Gen) BP-Swap
viewtopic.php?f=46&t=76390
Re: harness??
pretty sure BP harnesses work with engines whether its ford or mazda. if ur runnin the harnesses from the B6's tho u'll have to do some wiring. its not that big a deal. pretty easy to do.
						- Ryan
Re: harness??
Your SOHC harness should be perfect.  What is wrong with it?
A BP is a BP is a BP, for the most part (aside from some very irritating hardware differences if you got a JDM motor, ask John)
The harnesses should be very usable, either escort or Protege or Kia or whatever. The only difference off the top of my head, might be the fuel rail connector, but that's not an insurmountable issue, just cut off and solder on the correct one.
The other thing to think about is the TB. You need a TB to match your harness (ATX or MTX).
				resqrandy
Re: harness??
The Wire harness definately works cause thats the exact some harness I used. and I have a Mercury tracer BP, Protege fuel rail and harness, and an Escort Wire harness. Just remember ATX and MTX harness arent interchangable
							'99 F-150 Supercab Stock +Stereo System
'93 Mazda MX-3 1.8L BP05 5 Speed
Motor from '91 Mercury Tracer
ECU, Plug wires, fuel rail, Exhaust Manifold and Valve cover from '92 Protege
Wire harnes and VICS Solenoids from Escort GT
viewtopic.php?f=46&t=73674&p=548166#p548166
Photo Album:
http://www.facebook.com/album.php?aid=1 ... 711dabc18f
Photo Album:
Re: harness??
Thanx, my cars been up and running since jan. Love it
				resqrandy
Re: harness??
OOppssss  lol.. But hey congrats.
Photo Album:
Photo Album:
