broken horn
nitebatman
broken horn
Post by nitebatman »
Alright guys, I've searched through the past posts and saw that other people had this problem but what is the solution. When I press the horn nothing happens except a clicking noise coming from under the dash. I checked the fuse and the black relays and everything seems find. Is there something else I need to try or have a blown the actual horn and need to replace it? <P>If it means anything I did get a jump from a guy two days ago. Could that have caused the horn to break?
5spd_GS
Re: broken horn
Post by 5spd_GS »
heh you have officially joined the "what the hell is wrong!?" club<P>i wish i knew the answer but i got the same problem
Calen Sansom
1994 MX-3 GS Sparkle Green
