These noises are driving me INSANE. 95 Mazda MX-3.
My car makes this super annoying Star Wars Pod Racer style whirring noise, especially once I hit 40-45. It started a couple months ago but I think it's gotten in my head and it's seriously just making me absolutely hate my car. I have to turn my radio WAY up to even have a hope of drowning it out. On top of that, when idling, if I turn the steering wheel in either direction the car makes this buzz saw sound. It literally sounds like a buzz saw, and it's really pissing me off. All I want is for my car to STFU so I can listen to my music. It was suggested that replacing the wheel bearing would fix it, but god damn that's hard to do. I've done all the maintenance on this car with my dad so far and I'm beginning to think about just getting rid of it and buying something newer, but I work a crappy retail job and make like 100 bucks a week so this is a bit out of my reach (I'm 20, and I plan on being out of retail by August for nothing other than sanity's sake, cut me some slack).
Suggestions? Is the wheel bearing worth a shot? I pumped a ton of grease in there because I read that could also be the problem and it did nothing. We've replaced almost everything on this car at this point and I'm tired of it giving me crap like this once every 3 or 4 months.
Edit - I guess I'll also throw out there that we recently replaced all the struts. The old ones literally had no gas/resistance anymore, and you could easily slide them in and out by hand.
Sleeper6
Re: These noises are driving me INSANE. 95 Mazda MX-3.
To start with any way you can post a video of the noise? That would be more helpfull. Second if it is a bearing pumping grease wont do anything for you as they are sealed bearings that will have to be pressed out/in if thats the problem. To narrow it down put the car in the air and spin the wheels freely and you should be able to tell which wheel is making the noise as well as it should have play if you grasp it at 10 and 4 oclock position and pull on it. As for the saw noise what condition is your PS fluid in? Ild check into that before I relied on the music to fix it as that only tends to let you put it off till it becomes to big to handle.
Thank you for the very quick reply. I hadn't thought of checking the power steering fluid because typically my wheel becomes hard to turn if I'm running low and that wasn't happening. Lo and behold, it was totally empty and filling it up stopped the saw noise. I'm much less pissed about the car now ha. I will post a video of this noise tonight or tomorrow. Here's hoping my Evo can pick it up, though it's so un-godly loud that I cant see why it wouldn't.
Also, I noticed earlier that the spring for the strut on the same side of the car I suspect is giving off this hellacious sound is broken. It cracked at the very bottom and I was actually able to take a piece of it off. It's a good 6 inches long if I had it straightened out.
Sleeper6
where do you live at? If you are in the upper states/ca you can take the car to the dealer and theyll fix said spring for free. Otherwise if you are near NY Ill be glad to relieve you off that horrible machinery so you can rest at ease
Also side note is the noise coming from the outside of the car or the audio system? Alot of aftermarket radios will pick up interference noise from the bad grounds in our cars and transmit them through the speakers.
- Inodoro Pereyra
Call Anakin Skywalker. He knows a lot about pod racers...Patass wrote:My car makes this super annoying Star Wars Pod Racer style whirring noise, especially once I hit 40-45.
Diogenes of Sinope.
Diogenes of Sinope.
BrandonM
Its the bearing. Same thing happened to me. Its cheep anways if you do it your self. About 2 hours is all it takes.
I'm in CT but I've calmed down considerably ha. It's definitely not the radio, it happens when it's off too.Sleeper6 wrote:where do you live at? If you are in the upper states/ca you can take the car to the dealer and theyll fix said spring for free. Otherwise if you are near NY Ill be glad to relieve you off that horrible machinery so you can rest at ease![]()
How'd you press it out/in? We got the bearing, it was only 30 bucks.BrandonM wrote:Its the bearing. Same thing happened to me. Its cheep anways if you do it your self. About 2 hours is all it takes.
sounds like a bad wheel bearing for sure, almost like youre tire is completly oval moving up and down sounding, i had had this issue before, im not sure if there is a how to? but im sure it can be done for fairly cheap...
best of luck
best of luck
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
Previous rides
hgallegos915
AHH a too familiar sound HAHHA..
I wear bearings dont last me but at 250 thousand miles I guess I cant complain. LOL
Yeah sounds like a bad bearing. I HATE that sound... HATE IT.... :/
You get it pressed at a shop. Remove the whole spindle / knucke assembly. Take them the bearing and have them press it. OR go to a junk yard and get the whole thing. I got one for like 15 dllrs.
Better to go with new tho, used may not last.
If you are a v6, make sure you check the center shaft while you are at it, that bearing can go out too which mine just did. Luckily I had a spare shaft.
-hec
BrandonM
"How'd you press it out/in? We got the bearing, it was only 30 bucks"
Lordco did it for me for free, 5 mins. he just said bye.
Ok, we started attempting to fix it today...having trouble getting the axel nut off. Any special way we're supposed to do this?
We were using an axel nut socket and breaking bar but the thing just wont move, we're gonna go pick up an impact wrench.
- Ryan
Last time I did it I had a 5' pipe on it. I know that at least my mech puts them on as hard as his impact can do. Loose nuts cause premature wheel bearing failure.
the impact wrench we bought was defective, so we're trying again tomorrow I guess. Sigh. It's still lefty loosey on the front nuts right?
