Pulling While turning?!
ok to start i have a 94 mx-3 4 cyl dohc..Well i recently changed the passenger side wheel bearing (drivers side is good) but when driving if i turn the wheel to the left theres a slight pull to the left side. I have no clue as to what this could be. It only does this at higher speeds also it was doing this before the wheel hub work and turning to the right side is normal...thanks any ideas?
- Ryan
Re: Pulling While turning?!
toe out promotes turning.
toe in promotes stability.
I'm sorry but u lost me lol
- Ryan
Get an alignment
