Check Engine Light NEVER Stops Flashing.
JDMChris
Post by JDMChris »
Been driving a 96 MX-3 (1.8 V6 DOHC) and its running great.
Ever Since i can remember, the check engine light has been blinking.
Its not like there is a code showing.. it just keeps on blinking... over and over and over and over... lol
When Idling, When Driving...
Could it be the Aftermarket Gas Cap?
Any Ideas?
Thanks
mikeinaus
Re: Check Engine Light NEVER Stops Flashing.
Post by mikeinaus »
no to gas cap. have you checked codes before? http://www.mx-3.com/phpBB3/viewtopic.php?f=23&t=34787" onclick="window.open(this.href);return false;
JDMChris
Post by JDMChris »
Ive checked thru the codes.. but none fit my situation... it keeps on blinking.. no code... just blinks steadily and never stops.
Also, I have a gas cap... its not the original but fits just fine.. clicks n all..
slayer322
Post by slayer322 »
hmmm, i havent seen an engine light flash constantly, are the flashes the same length each time, all the time?
1996 Mazda MX-3 GS - DD / Always a project Car
ZE + Pacesetters = <3
JDMChris
Post by JDMChris »
yah i know, its weird.. just keeps flashing constantly. same length in between each time.
Its confusing.. going to try some things and post results
slayer322
Post by slayer322 »
I had a flashing CEL after i did my swap and it was because i had like 6 or more codes, it seems if you have too many codes, it flashes so you pay attention. After i cleared the codes, the flashing stopped even with 5 codes or less.
JDMChris
Post by JDMChris »
Well, i changed my alternator, as my sound system killed it.. and the light has yet to come back.
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
it's a 96.. get an obdII code reader/software.
Pure-Powder
Post by Pure-Powder »
Constant flashing light means you have a serious emissions problem.
JDMChris
Post by JDMChris »
Pure-Powder wrote:Constant flashing light means you have a serious emissions problem.
lol that could be just it.. my emissions are HORRIBLE. i need to fighure out how to fix it.. im changing my cat... what else?
Are you using a KL02 VAF? If not smack yourself on the side of the head then go get one.
spidlemx3
Post by spidlemx3 »
Hello, i have the same problem with my 1993 Mazda Mx3 V6, an my car runs like a top nothing wrong with it at all an the check engine light ALWAYS comes on an off constantly. i wouldnt worry about it to much, i worried about mine, but it was like that for almost a year.
JDMChris
Post by JDMChris »
Daninski wrote:Are you using a KL02 VAF? If not smack yourself on the side of the head then go get one.
lol KL02 VAF?
noob question but.. whats a VAF?
JDMChris
Post by JDMChris »
VAF = Vane Airflow Sensor
I didnt know it was on the K8... I thought it was on the probe n ze engines.
Where is that located?
mazdags94
Post by mazdags94 »
spidlemx3 wrote:Hello, i have the same problem with my 1993 Mazda Mx3 V6, an my car runs like a top nothing wrong with it at all an the check engine light ALWAYS comes on an off constantly. i wouldnt worry about it to much, i worried about mine, but it was like that for almost a year.
If your CEL is on or flashing, the ecu is trying to tell you that something is wrong. Go ahead and ignore it but you can do some major damage doing so...
If it's flashing, chances are, there are several codes that the ecu has stored. Jump TEN and GRND and pull the codes. If it's egr related, itll throw egr codes.
Ignoring it wouldn't have been the first on my list to suggest in terms of fixing the problem.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD :(
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
