[FS] - Various MX-3 parts
Re: [FS] - Various MX-3 parts
Ouch! $100bux for floor mats. Too rich for my blood. I withdraw my dibs
- Evo_Spec
yeah that's pretty pricey, but they are some of the more perfect condition mat's i've seen93SOHC wrote:Ouch! $100bux for floor mats. Too rich for my blood. I withdraw my dibs
i'm gonna withdraw on these items as i totally ignored cost and just got greedy calling dibs
Floor mats are actually $80 for the set, mainly due to using copypasta to format the list.93SOHC wrote:Ouch! $100bux for floor mats. Too rich for my blood. I withdraw my dibs
Next item: Measuring all the items already in a box and weighing them on a bathroom scale! Estimated date of completion for weighing and measuring in order to get more accurate shipping quotes = Saturday evening. Of course, this will not affect the local pickups :p
Mmore reason for you to get your a-- to Canadaland...hppwdn wrote:Hopefully Oscar has some info, I figured shipping might cost more than the hatch itself.
Also, all PMs have been replied to, and dimension and weight have been added in order to calculate shipping.
As a rule of thumb, shipping a hatch/hood within Northamerica should cost you no more than $200-$300 USD MAXhppwdn wrote:Hopefully Oscar has some info, I figured shipping might cost more than the hatch itself.
I was operating under Pakfeifer for many years and had a business account with Purolator. Its possible I get/got special rates but I find that hard to believe.
2 things you should mention when shipping big items like this:
Ship by ground of course and try to get a quote based on weight.
Some tricks of the trade:
WRAP THE PART AS TIGHT AS POSSIBLE TO ITS SHAPE! This will minimize unused volume and should cost you less.
Hope this helps..
I like the quaife, but its just too much $$$ for me at this point. Is it a direct bolt-on for us? or is there alot of work needed to fit it in our G-series tranny?
Will you consider lowering the prices?
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
Yes and no. That's just the LSD itself and it pretty much setup for a universal install. What needs to be done is that you need to take the ring gear off the Mx-3's differential (yep, drill out those massive rivets) and mount it to the Quaife using strong hardware.EZ_4_FUN wrote:I like the quaife, but its just too much $$$ for me at this point. Is it a direct bolt-on for us? or is there alot of work needed to fit it in our G-series tranny?
Instead of posting a new topic, reviving this old one. Car may be parked later in July and August and be stripped down due to rocker damage and low compression (Think low 110s) in cylinder 1. As things become available, they will be posted below. Of interest may be the power window motor on the driver side, which is about a year old, the power window switch on the driver side, the intact hatch privacy cover, rear wraparound spoiler, and a 95/96 distributor which is less than a year old. Also on the car are blue NGK wires less than a year old as well. Doors are rotted on the bottom edge.
Once the car is parked, everything is up for grabs >_>
I will not award "DIBS", but if you make a commitment to come out and look at something, I will not sell it out from under you before you've had the chance to come by. If you make said commitment and then flake I will send angry bees after you. It's that simple.
NOT THE BEEEEEEEEEZ!!!!!
It was a tossup between the dogs with bees in their mouths so when they bark they shoot bees at you, or the robotic Richard Simmons. As you can see, I am capable of compassion and mercy.
Pm'd on the rotors.
1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
Replied to most messages, plus a few pieces on the car are pending, including the OEM hatch and the CF hatch
- MrMazda92
My right kidney for all of the above?Flyer wrote: $300 (New) Polyurethane suspension bushings (90A lower control arm and trailing arm, 70A Lateral link) (5lbs, 12x9.5x4.5)
$300 (New) V6 traction bars, black (6 lbs, 13x11x5.5)
$100 (New) Full set of cross-drilled and slotted rotors
$500 (New) Carbon fiber hatch
Only two problems with that:MrMazda92 wrote:My right kidney for all of the above?Flyer wrote: $300 (New) Polyurethane suspension bushings (90A lower control arm and trailing arm, 70A Lateral link) (5lbs, 12x9.5x4.5)
1. The last two items are spoken for, assuming the people come up with the funds
2. I already have your right kidney. It was delicious.
- MrMazda92
I wish I had the funds, or I'd have probably jumped on #1 and #3 from that list immediately after you posted this...Flyer wrote:Only two problems with that:MrMazda92 wrote:My right kidney for all of the above?Flyer wrote: $300 (New) Polyurethane suspension bushings (90A lower control arm and trailing arm, 70A Lateral link) (5lbs, 12x9.5x4.5)
That's horrible, I didn't even know it was gone... Just goes to show how badly I treat my body!
