K SPORT COILOVER PROBLEM
mx3gulf
Post by mx3gulf »
Hey everyone, am from the uk, have got some issues with my new k sport coilovers. Think I have been sent the wrong ones, I think I have had 323 ones sent instead, The issues I have are that the rear tyres are not clearing the springs, the inside diameter of the springs are 2.5" and they are approx 9" long. in order for the springs to clear, they have to be wound down so much, to approx 6", that there is no rebound whatsoever, I have got onto my supplier and he is on the case for me and hopefully he can resolve it for me, but I am just curious to know if the spring length/diameter is the correct one, hopefully someone in the good old USA can help me as I know this suspension is more popular over here, has anyone else had problems with fitment? Heres a pic of my car, nearly there :wink:
TRACK BABY
1992 KLZE mx3, stainless manifolds, mx3 flywheel & gearbox, more to come!!
300zxrb26dett
Re: K SPORT COILOVER PROBLEM
Post by 300zxrb26dett »
Post a picture of the problem to help understand whats going on better, cause from your description, I am not understanding how the length of the spring is interfering with your tire or tyre;)
What exactly is interfering with your tire?
1995 Ford Escort- No its not an MX3, but it has lots of MX3 parts on it.
Modifications: too many to list, see the first page of my worklog.
http://www.clubprotege.com/forum/showth ... X-work-log
mx3gulf
Post by mx3gulf »
Can't post picture as I have taken shocks off. Let me try and explain better.......
When I bought car it had stock suspension fitted with lowering springs.
Have bought k sport coilovers, when fitting them I measured ride height from stock shocks and set them up to be 2" lower than stock suspension. you adjust the height by spinning the strut mount up for lower. The springs were hand tight + one full turn on the ring adjuster (9" long). I then fitted the k sports to the mx3. Upon fitting the wheel (standard 205/55/15/) I noticed that the inside of the tyre was not clearing the spring, its rubbing on it. So to remedy this I had to wind up the spring so it was 6" long to clear the tyre, but this has given me no rebound at all, go over a bump and the car bounces! Like I said, I think they are not the correct springs/suspension, therefore I am asking if anyone has k sports fitted to there mx3, if they could tell me there suspension settings
Hope this helps,
hppwdn
Post by hppwdn »
I have D2s on mine, same thing as KSports. I had no issues with my 225/50/15 tires. To fit my 245/45/17s I have to preload the springs to make them clear because the of the high offset of my rim combined with a wide and high diameter tire.
I can't see how you'd have any problems fitting a 205 width tire on there. Is your rim a really high offset? A 205 tire shouldn't be sitting close enough to rub the spring or perch on a fully adjustable coil over.
I'd have to see pics before I could post any further on the issue.
mx3gulf
Post by mx3gulf »
Have taken the bloody things off the car, but I will put put them back on at weekend and take some pics to show exactly what problem is.................
mitmaks
Post by mitmaks »
post more pics of the car, looks interesting.
hppwdn
Post by hppwdn »
mitmaks wrote:post more pics of the car, looks interesting.
+1, post more pics of the car. Looks like a cool mx3 from the one pic posted.
projectzemx3
Post by projectzemx3 »
lol makes it look like mx3s break down alot and often need to be towed.
NEED PARTS INSTALLED? PM ME!
_-Night-Shade-_
Post by _-Night-Shade-_ »
projectzemx3 wrote:lol makes it look like mx3s break down alot and often need to be towed.
LoL! I think he's trying to make it look like it's RWD cause FWD cars need to be towed from the front :lol:
mx3gulf
Post by mx3gulf »
Heres some pics
this is what she used to look like
I drive it like I stole it............. 8) :lol: :P
Have solved my coilover problem by replacing rear 10" springs with 7" ones instead............ Roll on track day 3rd of december :D
