I posted a [WTB] but seeing as how nobody has one, is there any place you'd recommend getting one?
The harnesses I am looking for are:
BP Engine harness
Interior Dash Harness (for the neutral safety switch)
Interior ECU Harness
I know you can just splice into the auto harness to bypass the NSS, but I'd rather have mine functional..
so yeah, Just curious if you know where to get them at.
Thanks a ton guys!!
where to get wiring harnesses?
Dark_Rider2k3
- Ryan
Re: where to get wiring harnesses?
scrap yards. pull 'em, unwrap, and rewrap them. good as new.
Dark_Rider2k3
Well.. I'm in the same predicament I was in with the pedal assembly.. I'll check again, but I do not think there are any manual cars in the lot. Though, I have not checked to see if there are any Escort's or Protege'sRyan wrote:scrap yards. pull 'em, unwrap, and rewrap them. good as new.
i've never had ANY luck with wiring harnesses at junkyards. best advice, is go to ClubProtege. someone there somehow always has one available. just be careful you dont get a jackazz who tries to rip ya off. put up a post and usually you'll get people pm-ing you and thats how you can do your lil "price checking" too.
Never be afraid to try...amateurs built the ark, professionals built the titanic.
- umcamara
I've aquired many perfectly good harnesses from the junkyard. Removed all the wrappings, fixed any corroded/broken wires, and re-taped. Takes a lot of work to get them out in one piece though.
