pieces in interior
mazdamxstyle
pieces in interior
hey mazda owners! I just painted my center vent but now i cant get off the ones on the sides. I also cant get off the center pieces (the one that goes around the deck and the one that goes around the stick shift) any help on how to get these off would be greatly appreciated thanks!
1993 Mazda mx-3 GS - Blaze Red (Totaled) Went through an 89 rx7 and a 93 del sol. Now searching again!
http://www.cardomain.com/id/mxmisl
white fish
Re: pieces in interior
they are just held on by clips just pry a bit for the bottom but mostly pull on it<P>be careful dont damage your dash
SmokyMcGee
there are two screws hidden behind the ash tray.. then two under the middle vents. hope this helps
I recently have done this. the side ones you have to pry out carefully but more forcefully than the center vents. To get the center piece off around the deck you need to remove the two screws under the center vents. it is just clipped on after that but is easier to get off if you remove the part around the shifter. four screws + 2 pop rivits hold the shifter piece on. two of them are easy to see, they are on the side and the pop rivits are with them. just pull the center piece of the pop rivit out and pull on the whole rivit to et it out. the other two screws are by the join where the ebrake section meets the shift section. hope this helps some
mazdamxstyle
Thanks a bunch guys, the 2 screws by the ebrake were the ones that were holding EVERYTHING together thank god for your help fellas, ill show you my pics of my halfway completed interior once the pieces are all painted, i have my seats done and new mats with red pedals and soon to be door panel in red cloth of some sort, my pics of when i juststarted my car are on <A HREF="http://drewlude33.tripod.com/carz0rz/" TARGET=_blank>http://drewlude33.tripod.com/carz0rz/</A> but i now have my other seat done with mats and some pieces painted, ill get those up soon thx guys!
