Anyways, as far as I know, there's no difference at all.
I'm glad you finally got it.
it was def. an mx-3....the manifold was looked really weird on it. i put the trannys up next to each other, and they looked identical, so im not sure about the axles and all......i didnt look for the markings...Redline322 wrote:It probably came out of a 1.8 sohc protege, look for a stamping, if it starts with f, you are good to go, if it starts with g, you might need to swap axles too because then it would have came from a 1.8 dohc. You should just have to swap on your speedo cable and wire up your neutral switch and reverse lights and be good to go.
