Trying to finish up my factory cruise control swap into my RS, and all my wiring and parts seem fine. Only thing I'm suspicious of is the module.
So has anybody had issues with their cruise module? There are no relevant search topics.
Cruise control modules prone to failure???
Re: Cruise control modules prone to failure???
I have one that doesn't work... haven't had time to test it out though... I suspect the vacuum...
remember those parts are old just like everything else... dunno how you could test the module - did you look in the BETM section?
The cruise button on the steering wheel is very problem prone. Never heard of the modual being a problem.
- umcamara
Yeah... There's a step-by-step troubleshooting procedure. The switches on the steering wheel weren't working but I took them apart and now they show the proper resistances when pressed, that was an easy fix.Mooneggs wrote:I have one that doesn't work... haven't had time to test it out though... I suspect the vacuum...
The module actually has a diagnostic system just like the ECU diagnostic connector, where it can throw trouble codes. But i can't even get it to enter the mode.
There's a procedure for testing the vacuum actuator under the hood by jumping/powering/grounding certain pins belonging to the actuator, and it seems to work (not a good idea to test it with the linkage cable still attached to the pedal cuz it redlines the engine in about half a second).
I opened up the cruise module tonight because I'd read online that certain car manufacturers had modules that were prone to failure and it doesn't look bad at all. 1 or 2 points on the PCB look a bit corroded, but that't it.
My resume Accel doesn't work, almost like it's glued, it's solid. I've owned 3 gs mx3's and never had a problem with the cruise module itself.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- umcamara
Yeah... I've tried 3 different modules now, 2 different neutral switches, 2 brake switches. I'm sure there's a wiring issue.
Icarus_27
The set accel button was really sticky on both of my MX3s but the cruise worked ok
onebrickshy
I'm on my second GS, never been able to make cruise control work
