Hi guys,
I have a question to you:
Is it possible to install a KL-ZE straight neck (the one with KL-31 cams) with a curved neck intake manifold and KL-31 ECU into a MX-3?
Does this version have advantages/disadvantages over a complete KL-ZE curved neck (the one with KL-01 cams) with curved neck intake manifold and KL-31 ECU?
Thanks for helping!
Tom
KL-ZE: straight neck with curved neck im
http://www.mx-3-tom.de" onclick="window.open(this.href);return false;
http://www.mx-3-community.de" onclick="window.open(this.href);return false;
SWAP COMPLETE: B6 DOHC (16V) --> KL-ZE (24V)
- Ryan
Re: KL-ZE: straight neck with curved neck im
You don't know this?
Everyone uses a straight neck motor and curved manifold, so it doesn't interfere with the brake master.
Most use Probinator to get the right VICS points, matched with the cams, and the vaf.
Search... its everywhere. This is probably the most common thread, things like this.
In Germany we install the KL-ZE curved neck (with KL01-cams), curved neck im, KL31-ECU and JE50-VAF.
I also drive this setup.
But the KL31-cams are giving more power, right?
- onlytrueromeo
The difference is that the kl31 cams are supposed to push the power up higher, peak torque/hp is moved to slightly higher rpms which is better for racing.
- WhiteFinish
Yes, its possible.
I use it as well.
I use it as well.
- Ryan
excuse my naivety, but are german cars RHD?
If you're RHD, both manifolds should work fine (I think?)
Yep, anything that is RHD will not encounter the problems that the USA people do.
I know because my straight neck fits nice in my engine bay (RHD).
1995 Eunos 30x KLZE
- muttpower
No, German Spec vehicles are not RHD. Only Japaneese, UK, and Australlian.
1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
German cars are left hand drive.
