![Image](http://i694.photobucket.com/albums/vv305/stereoking15/Scan0002.jpg)
What CFM does a DE draw at 6,000rpm?
- stereoking15
Re: What CFM does a DE draw at 6,000rpm?
sorry must post again more technical info
94 gs ze swapped,front mount oil cooler,b&g springs, kyb gr2 struts, vris deleted, gutted, racing 4 point harness. centerforce dual friction clutch, BREMBO ROTORS X4, CARBOTECH XP10 front pads, ebc green stuff rear PADS, corksport brake lines & clutch line, hei mod w/ msd blaster 3, MAZDASPEED motor mounts, B&M short shifter, M-FACTORY LSD, Carbon fiber hatch with lexan window.
trick69 wrote:Normally I would say your not stock, but depending on where you live atmospheric will effect your V.E (colder denser air) tricky tricky your trying to confuse me. I like it!! If your not boosted and your at sea level what did you do to reach 103% I'd like to know realy I would Cause I'll do the same thing to my DE. I figure a stock DE uses about 90-95% V.e. I would like to get that numer up cheap. dude jesse is looking to boost so I told him a number with 100% V.E cause he needs to hit that and go beyond to reach boost. What did you do please share HELP(port the heads?)kiwimx3 wrote:First off Im going to clear the air My post was in reply to Fowljesse, as I had started it then walked away from thetrick69 wrote:alright you want to get technical I will need the cam specs on the intake valve sizes and the flow rates of the heads. But since none of us know this I can tell you without a doubt the best ball park figure is 260 cfm without a doubt. the math equation I gave has been used for years it designed for sizing carbs to engines I've used it for years. And since I'm a mechanic I would say It is accurate. If you want to argue more I suggest you google search how to find this formula. And if your so smart lets here your awnser.
laptop, I certainly did not read untill this afternoon all your posts trick, if you think the comment was aimmed in
your direction, it certainly was not, and a lot of the older members on this board will certainly back this up.
If any offence has been given by my inattenion to not using the quote button I do apologise.
For the record a DE head flows 230cfm. as tested on a superflow flow bench.
As for your other statements, more so the one bracketed above, my KLZE for the record flows @ 6000rpm
289 CFM VE 103% BSFC .492 HP 213 TQ 186 ( So I guess its not stock then is it? )
http://www.mx-3.com/phpBB3/viewtopic.ph ... x3#p326237
tehbrookzorz wrote:Oh no, here comes the leafblower.
i about s--- my pants on that one lol
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
this doesn't tell me anything I don't know. but it's good info for those that didn't pay attention to a word I said.It's alright most people don't listen to me, untill they need something fixed and the've buggered it as much as they can
Somebody help! I ran out of gas so i put lighter fluid in my gas tank and now my car wont run?
![Shocked :shock:](./images/smilies/icon_eek.gif)
