ABS light on
ABS light on
I have a 1992 MX-3 Precidia with the 1.8 engine. The ABS light remains on. I checked for codes from the diagnostic unit. The light remains solid during this test without pulses to indicate the issue. I cleaned the sensors with no luck. I recall the last owner saying that the light came on when she got the CV joints done. None of the sensor wires look disturbed. Any ideas would be much appreciated.
- Ryan
Re: ABS light on
ignore it 'cause ABS sucks anyway.
Haha, did you try the troubleshooting section in the online manuals? It will be under "Brakes".
Re: ABS light on
Non abs cv's is my guess, thats my problem.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Re: ABS light on
Yeh, check to see if you have ABS cogs on your outer CVs. They should be in line with the sensors.
mazda___mx3
Re: ABS light on
if thats what the past owner said most likly the axle was replaced with the wrong one, there are 2 diffrent axles you can get abs and non abs, check to make sure the 2 front axles have counter teethe on the ends off them and the sensors are aligned and not to far away
