How to get Taillights out?
Guest
i havn;t looked at it yet but is it a big job to get the tails out? any tips? thanks.
Guest
Re: How to get Taillights out?
it shouldnt be all thet hard if i remember correctly it will me a couple of nuts in side the trunk the hardest part will be not droping the nuts in behind the interior.
- David Witherow
what.......how about lifting the hatch and there being two screws on top of the taillights and one on the inside edge then you push the light out to the side of the car it should just slide out.....
racefear
Tanks , this is what I am looking for !
_ ______________________________ _
MX-3 2.5 KL-ZE, kl-36 ECU, Millenia Intake, Outlaw Phenolic Spacer, Custom CAI, Catco 2 1/2 Hi-Flow Cat, Dual Megan Muffler, Mx3 Flywheel, Rear Strut Bar, Unorthodox UDP, Pacesetter Short Shifter, Cross Drilled Front Disk, Tokiko Blue Shock, H&R Coil, 17 inch white Motegie MR7 with Toyo Tire, Blue Metalic and Full Body Kit.......etc.....
14.61@97 MPH
14.61@97 MPH
