hesitation
- mitmaks
hesitation
This just started happening to me as the gas tank was nearly empty car would hesitate as I drove it, cutting out on acceleration then returning to normal. Couple tanks ago Ive put in some injector cleaner in it. Ive filled up today and hopefully that was just some air/moisture in fuel line. If it doesn't clear Im not sure what to do first, could be a number of things.
- Daveb
Re: hesitation
If you get to a stop sign & it stalls, but starts right up after a bit, its probably fuel filter. Change your fuel filter & add some gas line antifreeze (in case of water in gas). Fill her up with super
cheap gas-bad run mx-3
1994 GS 5 speed 1.8, fresh black paint, flowmaster muffler & Little smelly pine tree
1993 RS 5 speed SOHC with 89,000 original KMs! (rising fast though).
1994 RS 4 cyl auto- running parts car with 104,000 KMs
- Daveb
Re: hesitation
Sry, if it only acts up when tank is low, little screen on gas tank pickup or pickup, maybe fuel pump or gas cap ?
Under back seat, easy access.
- mitmaks
Re: hesitation
ya 100K is getting close, probably time to do fuel filters
- mitmaks
Re: hesitation
does this look like right part?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=" onclick="window.open(this.href);return false;
Re: hesitation
Yeah, just replaced mine while the engine was out. That's it. Depending on your intake setup, that thing could be the death of your knuckles. Total PITA.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- mitmaks
Re: hesitation
that's the one that sits by the tank or the one by the engine bay? I should replace both.Nallboy wrote:Yeah, just replaced mine while the engine was out. That's it. Depending on your intake setup, that thing could be the death of your knuckles. Total PITA.
Re: hesitation
That's the one under your hood.
By the one in your tank, do you mean the sock filter on the pump... or is there another one in line?
- mitmaks
Re: hesitation
Mx-3 is supposed to have 2, one in the tank and one in engine bay.
- Daveb
Re: hesitation
I d do the 1 under the hood first & see if it works. If not move along to the tank. Make sure you know the procedure so you dont spray gas all over.
Bad time for a smoke.
- mitmaks
Re: hesitation
wouldn't it make sense that one in the tank would get clogged first.Daveb wrote:I d do the 1 under the hood first & see if it works. If not move along to the tank. Make sure you know the procedure so you dont spray gas all over.
After thinking about it would a VRIS solenoid cause something like this?
- mitmaks
Re: hesitation
I have one of these on my Charger, you can actually see if its dirty and its way cheaper than one for mazda
http://shop.oreillyauto.com/ProductDeta ... =4&PTSet=A" onclick="window.open(this.href);return false;
Re: hesitation
I had something similar and assumed it was water in my fuel... my car would shut off when I turned right... after several tanks it would not cut off until I got lower like under a quarter tank... i finally used a product called HEET to remove the water and now I haven't had the issue since.
but I would also check your fuel filter too (kind of under the batter in the engine bay)... they can get really nasty
- Daveb
Re: hesitation
Bad gas/water can cause all sorts of grief. In my experience your main (cannister) fuel filtre causes trouble more often than the one in the tank.
Maybe because it picks up finer particles fron your fuel. Also the cannister has a scheduled maintenace swap & the tank one doesnt on most vehicles.
- mitmaks
Re: hesitation
I was driving it today and CEL went on for about 2 minutes then came off
