Need to find out what other trans I can use?
I have a 1993 gs auto. I'm tring to find what other trans I can use. I've been told by a few people that I need one from a 92-93 gs only. If anyone can help I would appreciate the help.
- Ryan
Re: Need to find out what other trans I can use?
Search on here. Its definately been asnwered.
When the info is so accessable, we get sick of regurgitating it.
The answer - any K series motor tranny.
- se7en
um, i think only mx-3 ones will work...
92-93...just swap out with a manual...
you'll never find a good used auto.
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
What manuals will work for my car? Out of what other cars and years.
- Ryan
Any V6: Mx-3, Mx-6, 626, Probe
You'll need all associated parts too, like shift linkage, speedo stuff, maybe axles... don't forget flywheel... I bet the starter too.
Ya, I believe Fieromx3 tried a DE auto trans in his without success.se7en wrote:um, i think only mx-3 ones will work...
I'm picking up a 95 gs 5 speed friday with a bad motor. So I should be able to use all the part from that. Thank you all for your help.
- se7en
That would work perfect
easiest way for sure.
I would like to thank you all. If I run in to any more problems along the way I will sure ask .
