solo_ryder - 1994 MX3 GS-ZE - Update March 17 - Goodbye
- Evo_Spec
Re: solo_ryder - 1994 MX3 GS-ZE
that looks great man!
would you be able to make one for a 4cyl too?
- rekognize
+1Evo_Spec wrote:that looks great man!
- solo_ryder
Sigh
Attempted to start the car today. It is not starting, it turns over fast but doesnt wanna start. I put the car in the ON position and checked the Orange power wire for the big disty plug and I am getting power, checked the red IG wire for the small disty plug and I am getting power there too. I think that the disty is toast. We will see, kinda funny it died when it was not in a motor...
- onlytrueromeo
I know you're checkin power, but have you checked for actual spark from your wires? Thats a sure way to tell your disty is toast.
- solo_ryder
Im the only one around. I gotta wait for my bro to come home.
- JM1EC-V6
Check your timing, ground points, and if there's any fire outpout to the plugs. Check the gas pump too.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
- solo_ryder
Timing is spot on as I had the car running for one day under a 93 harness/ecu combo.
Ground points are good.
I will check for spark when my bro gets home. I have a line on a 94 disty. So hopefully that is the issue.
- Ryan
How long has it been sitting... good idea to check your gas, might be a bit ucky.
- solo_ryder
just a few months, gas was some good 94 octane. Its not even close to starting. I will post up when I get another disty and it doesnt start...
Gas is only good for a few weeks technically, but you can get away with a few months, but it may depend.
3/4 of a tank from late Oct and my in storage ZE fires up no probs. Tanks are sealed so gas lasts longer. Check the plugs on your ECU?
I would use a bit of starter fluid just in case, the gas in my ATV goes bad after about 2 months.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated
-- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
SmoothMX3
Solo ...
When you get back on I.M. ... get up with me. I need a price on that intake.
36301
36301
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
solo...
im impress of what you've done to your car..very nice!!!! im fromm the philippines also,but i live now in brampton,on...i have a 94 mx-3 gs also and im planning to do some changes in my car..it's already 228,xxxkm...i got that from my friend for free..so im planning to buy for some parts that you still have..hope you can help me..
thanks,
trebor
thanks,
trebor
- solo_ryder
hoy hoy astig mx3 bata
PM me if you need anything. Thanks for the comment!
