1.6 sohc info
cricketol2
Re: 1.6 sohc info
Post by cricketol2 »
cool would u think they could do a dohc or would a 1.6 miata cam work?
nos92mx3
Re: 1.6 sohc info
Post by nos92mx3 »
No they wont work.
In a sohc engine design the cam operates both the intake and exhaust valves .
In a dohc engine design there are 2 cams, 1 for intake and 1 for exhaust.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
Limegreen mx-3
Re: 1.6 sohc info
Post by Limegreen mx-3 »
trying to beef up the sohc its a lost cause i know..
been there did what i could N/A then i boosted it
not anywhere as fast and my other MX-3 with the BP boosted..
cricketol2
Re: 1.6 sohc info
im not trying to have it as a racer im trying to boost the economy of it not hot rod around .. i have two of them one for racing the other for just normal driving
cricketol2
Re: 1.6 sohc info
nos92mx3 wrote:No they wont work.
i was talking about a 1995 dohc mx3 .. sorry i did not make that clear my bad
i have a 1993 sohc
and a 1995 dohc
Yoda
Re: 1.6 sohc info
Post by Yoda »
cricketol2 wrote:has anyone tryed to put a Throttle Body Spacer in if so did it do anything? and if so where did u find it or did u make it?
I use a tapered T/B spacer for a years. I machine one from 20mm aluminum in the R&D shop for my old 8V 1.6 SOHC until the car was scrapped. It was actually slightly smaller in diameter that the TB. It help to smooth out air flow at part throttle because as the throttle plate tip toward the air stream it creates turbulance before the TB. The spacer helps to smooth out the air flow to go around and over the leading edge of the throttle plate rather than swirl in front of it. At WOT the spacers smaller diameter causes venture effect behind TB creating higher air velocity within the IM. The end result the better fuel economy, more power at low/ mid throttle positions. There was no loss at the top end as result were inconclusive as to if the gains were from the spacer as don't consider a change of less than +/- 1hp a change but torque was up at peak.
cricketol2
Re: 1.6 sohc info
ok now about the pulley .. worth it or not .. and would a dohc pulley work on a sohc
thanks
Limegreen mx-3
Re: 1.6 sohc info
price for pulley and $$ for new smaller pulley belts not worth it if u want a 1hp upgrade and yes the sohc and dohc use the same pulley
cricketol2
Re: 1.6 sohc info
ok cool thanks for that info
so does anyone know if the sohc has OBDI or OBDII ? or something else? thanks
Ryan
Re: 1.6 sohc info
Post by Ryan »
SOHC is mainly OBDI, but if you have a late 93 (maybe early 94?) there may be some uncertainty.
