Light Above Ignition
My little green light above the keyhole in my ignition only comes on once in a blue moon i was wondering if there is something that might trigger it?
1992 Mx-3 GS White
1980 Spyder Monza(Torn Apart ATM)
- Ryan
Re: Light Above Ignition
Mine seems to come on randomly.... as soon as I open the door, after I close it, while I'm driving sometimes.... but its always off when I approach for the first time in a day, or after a long period of time...
i thought opening my door would turn it on but it dosent, i tried with both doors. its really annoying at night trying to find the hole, tee hee
1992 Mx-3 GS White
When you open you doors:
There is small button. In drivers side too. When you open door, green ligth turns ON. When you close door, green light lights about one minute and then turns OFF. This is useful at night.
I hade a problem when my light not turns on when i open drivers door, with passingers door was ok. So i repaired that small button and now all work just fine.
Sorry for my bad english, i hope you understand me.
- Ryan
That would explain my odd issues. I have that button half removed, so it doesn't beep when the door is open and the key in the ignition. I'm working on wiring a switch into that.
Thanks ill go take a look
1992 Mx-3 GS White
