Redo Rings Or Put In New Engine
Which would be easyer to redo rings or put new engine in mazda mx3. i would like some of your guys out put that have done it already. Thanks.
- Ryan
Re: Redo Rings Or Put In New Engine
What engine do you curretly have? If you have a V6, 90% of these guys will say go buy a KLZE (because its worth it). If you have a SOHC 4 cyl, most will say go with a BP, and I don't know about the DOHC 4 cyl.
I have the v6 Gs
common sense says swap in any other engine.
Financial wise its cheaper to get a klde than to rebuild your stock engine. Even a kfze will work(pretend its a new stock k8)
best bang for the buck is a klze swap.. its simple, clean.. not messy.
you can also get a us spec millenia ze. Its a bit slower than the curved neck but its good.
-hec
ok where would the easiest place to order one from
- ElectricEnergy
Jeeze Ashton,
Get me on msn djek@shaw.ca" onclick="window.open(this.href);return false;. And I'll be able to point you in the right direction for some things. The best place around here seems to be JDMsource in Calgary, but they may be a little overpriced.
David
David
Were are you from?
Is this a sask guy?
Is this a sask guy?
- ElectricEnergy
Yeah, he went to high school with us.
WHAT
jesus. Cool, ashton add me on msn tykrause@hotmail.com" onclick="window.open(this.href);return false;
And buy a KLZE if you have money, me david and tyler have all done the swap, we know our way around these cars pretty good.
