Will I be able to get away with running these? I checked the valves and all that stuff. none are bent, everything else looks good. The head gasket is cooked around the rings, the car was leaking oil really bad. The guy i bought it off limped it home from Lloydminster, which is a few hours from here. When i bought it, it would just barely idle. myplan so far is to just clean it all up, slap a new head gasket on, and get rid of the car. Its too bad, I really like this thing. Tell me what you guys think. Is this going to cause me a big problem? from what i can see, the rings are still intact, and there is no interference with the valves/pistons.
cylinders 2 and 3
(im aware its not at top dead center)
and could someone tell me what the hell this thing is that i tore up after the manifold...
i know, im dumb aha... for backpressure or what?
oh yeah.. i forgot to introduce myself, im brandon. from saskatoon, saskatchewan.
heres some pics of the whip.
1994 MX-3 RS, B6-DE
any help, or oppinions would be greatly appreciated
