more power
more power
I was wondering if anyone knows about any more performance mods other than an intake for the DOHC 1.6L? Please list a few if possible.
maine_mazda_bp
more power from 1.6
you could use adj camgears ,bump your timing, some say you can take an exust cam and use adj cam gears to install it on the intake side iv seen this done to the 1.8 bp and it was dyno tested and gave 12 hp .The best way to get more power for the least money is to add the 1.8 bp from a escort gt or mazda protega the dohc 1.6 is said to only have 88 hp in the mx-3 and the 1.8 BP has 130hp plus you do little mods and you can have it at 150hp thats a that would be a 52 hp gain
94mazda-MX-3 5 speed with bp swap have gt25 turbo with some turbo parts but its not on yet waiting on more stuff building a mega squirt2 for it but body is stock
maine_mazda_bp
bp swap
it is not hard at all i know 16 year old kids that have done it the hardest thing is puting it in place every thing bolts right up just need the bp motor mounts well worth it if you do it your self your looking at the cost of the motoe and the motor mounts
- cyclonekid78
The wiring would be the hardest part. The swap is easy.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
mzdamx3rsdohc
Re: more power
bump the timing, get a highflow or gut the cat. muffler with 2.25inch cat back piping, if u dont have a intake buy or build a home depot one. listen at 4800-4900 u should hear the engine sound change to a louder deeper pitch and u will notice it accelerate faster, not much but noticeable in 3rd and 4th more than any other gear. if u do not notice this then under ur intake manifold ull see a little canister with a rod out the bottom and a vacumn hose out of the top. wiggle the rod up and down and spray it with some wd-40. 14 inch aluminum stock wheels over the steelies make a difference i thought. take first to the rev limiter and keep the gas down on the 1st-2nd shift this will spin in 2nd for a sec but ull catch 2nd in vics instead of around 4200-4400 waiting for vics. remove ur spare and sound deadening, i went as far to remove the heat guards between the exhaust and floor as they usually rot and rattle neways, either way it will never have much power unless u get blown...lol
dohc b6, intake, exhaust, miata cams ready to go in
- Limegreen mx-3
Re: more power
94-96 rs 1.6 dohc is rated at 105hp at the flywheel
92-93 rs 1.6 sohc is rated at 88hp at the flywheel
and even lower at the wheel.. gotta love mazda power
Re: more power
lol yup and even worse when you got a 105hp motor and a p/s and a/c robbing it. how much you loose to the wheels again? isnt our b6 dohc around 85whp. gotta love it
1995 mazda Mx-3 RS 1.6liter DOHC B6-DE
mortenmorfar
Re: more power
you should try my previous car, a Citroen BX 1.9Diesel, 60Hp to 1150Kg
, it was seriously slow, but the suspension mmmmm nice
Re: more power
wow but how was the gas mileage on your car? our saturn has about 88hp to 2400lbs and its kind of gutless.
mortenmorfar
Re: more power
it was a 83 diesel engine (XUD9) with 650.000Km on it, it did 17-20Km Pr Liter, but when it started to leek air into the fuel, and i tried almost everything to fix it, I sold it and bought my MX-3
Re: more power
thats crazy i dont work on diesel engines too much. ya the mx3 isnt the most powerful thing in the bunch, but its not a common car and better then most. in handles amazingly even with the suspension thats 13 years old. the bp swap for this car seems to be the best way to get alot of hp while still being a good daily driver and not going turbo.
Re: more power
pick up a turbo manifold and turbo from the gtx, direct bolt on. Get an SDS extra injector controller to add fuel. Run 15 lbs for 200HP. Run it rich.
Tried NOS, Tried turbo, tried 1.8 w/ NOS, NOW V6
Re: more power
