no heat
- ScooterBovine
- tehbrookzorz
- tehbrookzorz
Highbody wrote:
the heat gets warm
High.... Warm heat... Is your username too honest?
What's your situation highbody? Are you losing coolant? Is this when the motor is already warmed up?[/quote]
the heat gets warm
Last edited by tehbrookzorz on December 27th, 2007, 12:55 am, edited 2 times in total.
Cody
- tehbrookzorz
I kind of wonder if the impeller on your water pump is worn out (I've seen pictures of a water pump that looked... not like a water pump), but I'd hate to say pull it out only to find that it's not the problem. Replacing the water pump is a big job on this car. Maybe there is a blockage in the cooling system or heater core, or an air lock. I would make sure the coolant level is topped up and the air bled out, and that there are no leaks, then go from there.
Cody
meh my heat is not working as well...
Methanoxide
I had a similar issue it would always blow warm air and never quite heat up up like my previous vehicles.
I sourced the problem to the pipe hanging half way off the blower motor, passenger might have inadvertently kicked it off... Blows really hot now!
Check up under the passenger side foot well at the blower motor and make sure everything is hooked up securely.
Re: no heat
i flushed the system and the water pump just got changed when i did the timing belt... both didnt solve the problem... Im swapping out my broken dashboard this weekend... ill poke around under there...
Just so i know the blower motor is over neer the ecu? or is it over neer the Ac stuff?
- Custommx3
- Site Administrator
Re: no heat
I believe its under/behind te glovebox.
What year is your car..
if your slider on your HVACS is broken or strteched, it wont turn the "flap" that swaps from cool to heat.
Read the online manual for locations of the cables.
Re: no heat
just replace water pump, i just had to do this ,and while your at it do the timing belt and kit also if you have the extra cash throw a underdrive pulley on there as well!
1996 mx-3 black 1.8 v6
Re: no heat
its a 92 ... ill tinker aound under there and see whats happining... hpefully i can find it before the really cold weather hits...Highbody wrote:i flushed the system and the water pump just got changed when i did the timing belt... both didnt solve the problem...
Re: no heat
i looked around under there today and didnt notice anything abnormal... i dont understand why it blows cold at idol... could it be my heater core?
Re: no heat
It could be that your heater core is clogged. When moving you may just be getting heat from the engine bay coming through the firewall somewhere. Try taking out the core, and having it blown out. Just a thought.
1992 Mx-3 GS. ATX to MTX swap. Integra short throw shifter, and CAI. HEI mod. Accell Canister. 3A racing muffler. Straight pipe.
