how fast am i going in the dark?
please tell me cause i dont kno...my gauge cluster isnt lighting up when i turn my lights on...the other lights light up like the check engine and e brake lights things like those...but not the gauges...any suggestions? thanks
1993 MX-3 w/ straight neck KLZE swap...Probe GT 2.5in headers, Custom exhaust w/ test pipe and OBX Twin Loop Tip, Bully Stage 3 Clutch, Fidanza Flywheel, Pheno Spacers, HEI mod, Blaster SS coil, Probinator chip, TWM short shifter, AWR front and rear mounts (88 Durometer), and Corksport braided clutch line...so far
Ever see the lone rider of the night? Well he'll find you and then you'll never him again...
- lowflyinmx3
I had a problem just like that. my problem was i had a loose wire under the dash. check around and wiggle the wires around if you need to. when you hit the right wire your lights will come on and you'll hear the idle drop. my wire was lose becuase the previous removed the security box and didn't put everything back together tight. hope that helps. also check your fuses.
Mazda.... What happens in the parking lot, stays in the parking lot
lol true but I doubt they ALL went out at the same time. Check the wires around your dimmer switch - if one of those is pulled out none of your dash lights will come on.umcamara wrote:Could also be burnt out cluster bulbs, they're very inexpensive.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
well someone had installed a security box in there prior to me purchasing and was one of the worst electrical jobs i have ever seen so it might be that but ill get under there tomorro and wiggle em around thanks for the help
Re: how fast am i going in the dark?
95MPH. Hope this helps.
Careful with the cops.
- umcamara
His speedo could be off though. I was gonna say roughly 97MPH... just to be on the safe side.SuperK wrote:95MPH. Hope this helps.
Did you ever fix this prob?
<a href="http://www.fodey.com/generators/animate ... .asp"><img src="http://r3.fodey.com/117ef9486659942269d ... 7601.1.gif" border=0 width="404" height="110" alt="Ninja!"></a>
no actually i was planning on fixing it and a few days later my engine blew and since then ive been workin on putting a KLZE in so after that im gonna try again to fix it...any info?
no i just have the same prob and i wanna fix it
