Ok so Ive been looking at getting some GC coilovers cause I really hate being as low as my carwas with Koni inserts and H&R springs at times but at other times I loved it. I was reading through some sites that sell them for around $400 and that doesnt sound to bad and then I read you have to fit them to the stock struts or a set of tokicos. Can I put them on the koni inserts ive got or am I going to have to get some new struts?
Steve-O
site for GC's
http://www.eautoworks.com/html/search-1 ... spring.htm
							Koni insert + GC compatible?
- sk8erdude802
93' MX-3 GS SE ZE   - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
MyFeedBackThread
It works.
Koni`s use stock strut housing, so no problems.
You might want to do the install properly though.
Luc St. Pierre had a page with how they _should_ be installed for the best performance/safety. But seems it`s not online anymore.
Ah, found it :=)
http://web.archive.org/web/200702070335 ... rlu/gc.htm
The pics work if you click the links where they should be.
-n
Ah, found it :=)
-n
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
						- sk8erdude802
Well Well...now if I could only weld...if I could weld Id probably build alot of cool things....a bagged truck being one of them. wonder how bad it would be to not weld them or how much to have them welded. Ill have to start looking around for someone around town that can do the job.
Steve-O
							Steve-O
MyFeedBackThread
MyFeedBackThread
- mx3autozam
You dont weld the sleeve to anything.
You weld the metal rings you need to get machined, to the strut.
The pics show how it works.
I`ve done it this way myself, and dont regret it at all.
Looks more professional not having the spring perch for stock springs.
-n
-n
						- sk8erdude802
Sweet. I really liked the way they looked welded in there. I figured it would look kinda goofy with the stock sprint seating in there.
Steve-O
							Steve-O
MyFeedBackThread
MyFeedBackThread
