Up for sale is the COMPLETE drivetrain...
Engine, Transmission, ECU, Engine Wiring harness.
Anything pertaining to the RS motor and trans I will not need.
This also includes the shifter.
Not sure on mileage of the motor/trans since I accidentally pulled the speedo cable off when I was taking the cluster off for gauge overlays.
I got the car with 180K on it and prob put in a good 10K on it.
But is working fine with the exception of the water pump needing replacing.
It also needs to be retimed.
I will also include the new water pump as well.
I will not part out individual pieces.
Just complete engine, transmission or ECU for sale.
Will be out of car in Dec, so if youre local and want to hear it run and drive let me know...otherwise...it will just be a full drop
Also available is the rear axle.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/MX3Forum/Forsale/IM000237.jpg)
