Thanks!!!
WTB Master power window switch
rockfordgirl
My master power window switch located on the drivers side door decided to stop working... i got it checked and its not the wiring...(plus the button came off because it was raining and my window wouldnt go up and i was trying too hard to make it go up LOL...) I called every single wreckers in the Kawartha area but non of them have one... i called the dealership and they want 170$.... if anyone has a working master power window switch that they would like to sell to me could u contact me
Thanks!!!
Thanks!!!
- Tunes67
Your best bet would be to check e-bay for them. Most of the folks that have them on this site usually want to keep them as spares for this exact sort of thing. But they pop up on ebay fairly often for under $100.
Tunes67
Tunes67
rockfordgirl
I know this can't be a good way to open my window (my switch also broke =\ ) but if you can find a hanger or other metal wire type object you can sometimes sitck it in the right spot and work the switch after it brakes off.
but sometimes it still needs a bit of force to actually close the window all the way. I think its the insulation between the door and the window slowing it down (for me at least)
Only problem is when you only want to open it a little sometimes the auto open kicks in (sucks when its raining out..)
