aftermarket wheel
aftermarket wheel
i have a gs and a grant adapter and colin and I are having some problems getting the horn to work on the adaptor how did everyone else make it work we tried taking apart the clip for the cruise control and it doesnt work please help me
Always under construction
C'mon guys..both you guys should know how to search, and even then, you didn't even bother to ask me? Shame on you
You could even ask Deimos (Ian), he's done it too...
I'm off to bed, I've got a 13hour drive tomorow, but here's a thread on the cruise control controls, I believe there's info about the horn in there as well...
http://mx-3.com/phpbb2/viewtopic.php?t= ... 3905a33b68
I'll look more later, but if you look for cruise control control threads, you should be able to find related information about the horn
Just one note, that may be in that thread, but on the hub, on some hubs anyway, the connector in it isn't ground, so if your connecting to it, it won't do anything
Re: aftermarket wheel
HOLY SMOKES I just got my horn to work last night at 11pm LOL I was having the same difficulties! I have a MOMO aftermarket steering wheel and MOMO hub adapter.havoc13 wrote:i have a gs and a grant adapter and colin and I are having some problems getting the horn to work on the adaptor how did everyone else make it work we tried taking apart the clip for the cruise control and it doesnt work please help me
In my 92 GS I completely removed the cruise control ring then I took it apart and reinserted the middle piece inside of the ring with the little metal things sticking up. I took it off the black backing. I then put this in between the housing for the ring and the hub adapter. This creates a contact point for the hub adapter to touch.
Basically the GRAY wire is the wire that goes from the GREEN/BLACK in the horn relay. this needs to remain connected to the ring.
I still have my cruise control working I just relocated the switch!
There is also a BROWN wire and a GREEN/RED wire - these 2 are for the cruise control. I haven't figured out which wire goes to which because from the ring to the cruise control buttons it goes to like blue and black...
I don't have any pics cause it was really dark! Remember you may need to reground the horn if you just hear the relay clicking and nothing is happening. hope this helps....
Let me know if you could use the Horn pages from the Body Electrical Troubleshooting Manual...I can scan them in and send them to you. I've already given you the wires which is all the pages will tell you... it's just trial and error trying to get it to work... good luck!
