you know that lil radiator over the lower hose in the radiator that goes to a tube around the thermostat area, is that a return or inlet hose!?, the reason im asking, is because i busted my radiator yestarday trying to take my alternator out, so when to the junkyard and got a used one, but it that that tube in the radiator welded\blocked. so i had to put a plug on mine too.
i already installed the radiator and tested it for 30 min, and everything seems to work fine without that hose.
i know the hose goes to the idle air control on the TB. but is it returning it? or sucking it?
radiator hose
radiator hose
93 mx-3 w/ Curved Neck klze
Its just a hose that passes radiator water from one bank to the other. Im thinking of bypassing it if its possible. I think it helps with the pressure.
-hec
