Can someone help me decipher the wiring to my combination switch?
I looked at the online manual and some of it isnt clearly scanned...
And the wires seem to be different colors...
since Im working with a 92 MX3 RS rather than a 95.
I have a new combo switch with the new connectors...but I have to take the old wires and put them in the new connectors.
It would have been easier if I still had the stock connector.
So this is what I have as far as wires...Im just not sure of what they control.
These are the wires that are right at the combo switch.
****TURN SIGNAL/LIGHT CONTROL*****
Grn-Red []
Red-Wht []
Blk-Grn []
Grn-Yel []
Red-Blk []
Red []
Wht []
Blk-Red []
Grn []
Blk []
Grn-Red []
*****WIPER CONTROLS*****
Light Blu-Red []
Light Blu-Org []
Light Blu-Wht []
Light Blu []
Light Blu-Wht []
Light Blu-Yel []
Grn-wht []
Light Blu-Red []
Blk-Wht []
Need Combo switch Wiring Help
Hey, THANKSshameem wrote:Download this before the link becomes unusable....
http://www.mediafire.com/?4dmaxt4vhmc
By any chance you have the part that tells you the pin out connections?
Just wondering I just browsed over what you gave me...
It is in depth...but just couldnt find the part that tells the pinout connectors.
I know know what wire is what...but dont know where to put them.
Thanks for your help.
I will check that out.shameem wrote:I havent seen connector pinouts for 93 anywhere - you can try the online manual page Z-066 and go from there.
Odds are - the wire colors will be the same before and after the connector - so if you know what wire does what - you can pretty much "know" the pinout....
the reason I was asking is a lot of the manual isnt scanned clearly...
I cant tell if someing is a O or a B.
Ill try and tackle this problem by this weekend...
Or if someone out there has a nice clean scanned copy of pages
Z-062
Z-063
Z-066
