KL-ZE questions. please help.
OK i have a straight neck, and i relieze it wont fit with out modifying Alot of stuff. So i would like to know if theres any detialed descriptions of how to make my k8 IM work, or if it even will? For now, or at least untill i can get a curved neck. i heard it will fit (not shur so i need help) but restict air flow, in that case couldt you just get a dremel and port match it for a little extra porformance?
Any help with the fitment or anything would be great!
![Image](http://i240.photobucket.com/albums/ff68/zoomzoommx/Untitled-1.jpg)
he does keep it a secret but its very easy to figure out what needs to be done to fit it in. you just need to address why it wont fit, and what could you do to make it fit, its actually a pretty easy fix. I know how he did it but its his secret and i've agreed not to say anything on how to do it, but i always try to drop hints. And before someone says it, he isn't being an a-- by not telling how to do it, there are other members on this forum that have it done as well (and no i dont mean griding off part of your TB or mounting your TB upside down, thats the wrong way to do it).
if you have a straight neck and you dont want to deal with the hassle with trying to modify parts on the IM to make the straightneck fit, you should just find a millenia IM, would be your best bet and will not restrict airflow, you can also use a mx6 or probe IM but they have round ports and not the square. the Millenia IM's are pretty easy to find, then junkyard here that moca goes to seems to always have a few in stock.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
yep it will bolt right up will just restrict airflow, make sure you swap the fuel rails you dont want to use the k8 injectors you will starve the engine of fuel
since your using the k8 IM you can use the diagram on your hood to hook your vacuum up, dont waist your time trying to port match the IM, its not going to help that much, your still going to be restricting airflow
