I've got a few dents from the previous owner (including a pretty big one on the driver's side near the back end), some small spots of rust, and most of the seals (door, sunroof, etc) need replacing.
Should I be expecting like $1500? $3000?
Can body shops generally change a windshield?
Also, there's some rust on the bottom of the car (especially above the exhaust).. can bodyshops grind out the rust and put a sealant on the bottom? Is it a good idea?
And finally can anyone recommend a good one in or near Montreal?
