Couple Motor Questions
Hey so im looking at a 92 MX-3 with the 1.8l DOHC in it, and i'm wondering; is the motor an interference motor? How often should the timing belt be changed and how hard is it to do? How long can these motors last? Whats the fuel millage like on them? and lastly How hard is it to find Parts for these motors?
Thanks
Matt
Thanks
Matt
hgallegos915
search for the word "interference"
-hec
- XxantwawnxX
its NOT an interference motor. not sure on the milage...ive had a diff motor for the longest time. and its not tooo bad to find parts.... its gotten alot better anyway. but it AINT no honda.. ; P (meaning you cant find parts in your cereal box.)
Smith18
Fuel millage is kind of crappy for this small of engine, from factory it gets 20-26 MPG (give or take a few) and it depends on how you drive it to. Its alright to work on, most of the stuff is easy once you get down to doing it. Hardest thing to change is probably the timing belt, its do-able with the engine in the car but can get pretty hard suppose to change it every 95,000 kilometers. These cars can last a long time if you do your regular mantince, there a lot of people that had gotten them over 200k miles!.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- 1992blazeredgs
- 1992blazeredgs
- mr1in6billion
I get over 30mpg (50kpg) in the city (huge hills, stop signs on every block). Granted I drive the 1.6, but I can't imagine the 1.8 gets 4-10mpg less. A tank generally lasts close to 500kmSmith18 wrote:Fuel millage is kind of crappy for this small of engine, from factory it gets 20-26 MPG (give or take a few) and it depends on how you drive it too.
Mnemonic
My mx loves gas, mmm mmm mmm Premium 3.30 WOOO
no the v6 is not an interference motor, its a hemisphere though
a k8 should get around 25mpg, maybe a little more if you learn to keep it below 3k rpms (always hard to do)
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
