gas cap problem
				92blackmx3
gas cap problem
whenever i take my gas cap off its built up a lot of pressure this cant be a good thing and what can be done to fix this is there a vent on the tank that might be plugged
						- mr1in6billion
- PATDIESEL
Waht- acutally just the opposite. It is supposed to seal, but release pressure beyond a point, thus the clicking when you tighten it. Buy a new one, they are 10 bucks...
				mazdamx3sohc
				m90daytona
				mazdamx3sohc
- Tunes67
It shouldnt be building pressure..  the sound your hearing when you unscrew the cap is negative pressure or the sound of a vacuum being released..  air is being sucked into the gas tank..  and this is normal.  Our gas caps are non vented and this is part of the emissions control system of the car.  Many emissions control places check the gas cap according to factory specs..  so if you want to run vented..  make sure you keep a spare one that is non vented for emissions testing.
Tunes67
							Tunes67
"So long..  and thanks for all the fish!"    "Momma says VW Bugs are the devil"     "This one time at band camp..  I stuck a flute in my Throttle Body"
				mazdamx3sohc
				92blackmx3
