So heres the story, went to get emissions test and failed horribly. HC ppm was bad & I'm blowing some smoke during startup..oh and it's leaking oil all over the place.. I haven't found out where yet, gotta shampoo it... Here's the emission test results for the HC ppm :
2500 RPM Idle
limit 200, reading 369 reading 283
SO then I decided to see if I could see where the leak is.. too oily (been sorta leaking for a bit, now its bad).. then I decide to pull the spark plugs.. cyl 1 seems ok..cyl 2 spark plug is covered in oil!! and when I look into the chamber I can see oil! Now I'm thinking the head gasket is done (leaky oil??) and the chilton book says valve seals or piston rings!!! WTF!!!
Um... soo since I have no idea what this would cost for a mechanic to fix... I can bet that I don't have the cash for it.
Sooo what am I looking at here folks??
Is this something that an intelligent man with some tools and a little knowledge and fast learning can do?? (I have been doing minor repairs on the car already and have a decent knowledge of how one works)
or does anyone have an idea of the 'repair shop' cost or leads on an engine??
Thanks
funkyfreak
'96 mx-3 4cyl DOHC auto.
