Sometimes I have trouble putting the car into reverse. It's like the gear stick lever doesn't feel like it's in quite the right place - no solid thunking feeling as it slides into gear, you know? When this happens, I have to let out the clutch, push it back in, and then try the putting it in reverse again.
Someone told me this was a common problem, and could be adjusted. Does anyone know what I'm going on about, and can I adjust this myself?
