Any way I can test my O2 sensor without using that SST thing in the manual?
I got a code 24, and I did have acceleration problems (occassional jerking), so I'm suspecting a O2 problem. Want to make sure that it is the problem before buying anything.
O2 sensor
I beleive you can check them with a regular voltmeter, not sure. Usually when it throws the code they should be replaced. It would help your miliage to replace them if they haven't been replaced ever anyway. I got mine HERE , 50 bucks each shipped to canada. Plug n play. work fine, came quick.
Thats where i got mine too! Its still sitting in my desk wrapped.. my car was trowing the code, reset the ecu and no more codes and its runnig fine? o.0 odd. Ill replace it when this crazy el paso weather gets better and I stop being lazy. (which is never)
-hec
