BP N/A Question?
BP N/A Question?
from what car comes the best (fastest) BP N/A?
- Josh
truth is the fastest FWD NA BP is the Ford Escort GT but it was only due to tunning, and i thing it was good for like 129HP or something. and the Mazda Protege was good for like 125
but if you want to get the best BP you will want one from a 99-02 Miata, i think there rated somewhere around 140, i dont rember for sure. its not hard to swap all the plumbing over to FWD from RWD, just bolt ons. your best bet would be to swap the wiring harness and ECU over as well.
- Limegreen mx-3
just to let u know its been done i have 95 mazta miata BP that i converted to FWD form and i am thinking of getting a 99 and doing the same but thats time and money. time is what i don't have always working.
only thing about the 99 bp is the intake side is different then the older BP's u can just simply swa out the head from the older Bp and promblems sloved.
the best thing about the 99-00 or 04-05 msm bp engines is the head
it's the best flowing bp head
lot's of info here
http://members.aol.com/solomiata/MX5Engine.html
lot's of info here
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
- Josh
you can use the older intake manifolds. it just takes notching out some of the bolt holes, and i think dremeling out one or two of the ports just a little.
I will like the mazda protege bp n/a engine from wish year it will be better?Josh wrote:truth is the fastest FWD NA BP is the Ford Escort GT but it was only due to tunning, and i thing it was good for like 129HP or something. and the Mazda Protege was good for like 125
WingleBeast
- Limegreen mx-3
[quote="Josh"]you can use the older intake manifolds. it just takes notching out some of the bolt holes, and i think dremeling out one or two of the ports just a little.[/quote]
its more to that then what u said. the intake ports are higher(99-02) than the older bp ports. iam just going to have to take a pic and show u what i mean.
- Limegreen mx-3
[quote="Marlon"]99+ intake port mismatch with 90-97 gasket
[img]http://members.aol.com/solomiata2/99int ... smatch.jpg[/img][/quote]
THERE U GO THATS WHAT I MEANT
- Josh
i was told that several guys are just slotting the bolt holes and sliding it up.
