Yes, I did a search - I just want some new wisdom.
96 RS - VC was leaking (front right and at distributor hump), so I replaced it with a new gasket from the dealer. The old gasket looked perfect when I took it out. I applied gasket compound around the distributor. I tighted the VC in the order the shop manual describes, with a torque wrench. I did 55 in/lbs. It was fine for a week then started leaking again, at the front right. It isn't much, and it's not right at the distributor hump either. Since then I've re-did the bolts again at 60 in/lbs, then 65. Not willing to go higher, really. For what it's worth, I'm using Mobil-1 5w30, recently changed. Been running this for 5 years, nothing's changed.
Anyone have any ideas? Maybe less torque? If anyone has any insight or experience with this, let me know - it's getting annoying.
Valve cover gasket leaking, even after replacement
- jumboplay
-Tom J, proud MX-3 pilot-
Get your entertainment upgraded at http://www.tommyv2.com
1996 MX-3 RS/GS hybrid, OBDII B6-ZE, painted Mazda crystal white, ZX-2+Eibach, Miglia Spyder 17"s, markerflash, black altezzas, insane fuel economy, too many other mods to list...
- OROutdoors
Jumbo, Good trouble shooting. Here are some other things to consider. Have you inspected it very closely and verified there are no cracks? Also, have you checked the head and the cover for flatness and/or scratches on the surfaces that mate with the gasket? Is the new gasket faulty? Is the oil leak possibly from a stud or bolt hole? Good luck,
Oregon Outdoors
92 mx-3 GS lowered, CF hood
2013 Mazdaspeed3
2013 Mazdaspeed3
- Josh
what always works for me is before your selent clean the area with gas or thinner, carb cleaner. after applying your selent, just set the VC in place and dont torque it down for at least 2 hours. and i never torque it, i just put a long extention and hand tighten all of them, then give about 1/2 turn with the wrench.
have you checked your distributor seal, often it comes from there.
- jumboplay
Distributor seal replaced too. It was leaking from there, but it's not since I've replaced it.
mazdamx3sohc
- atlantamx3
mazdamx3sohc
