And here is one of the two top plates they include to make an actual enclosure for it, theres a neat little OEM air scoop under the car that vents this enclosure. Its S-shaped so water is less likely to get through.
The coolant overflow I just bolted right below in an already existing hole and the MAF sensor didnt give me too much trouble getting it out of the way of the disty.
 I have turbo dreams and detanation nightmares
