head gasket and bent frame.. Screwed?
MeNtAlPaTiEnT
Ok, so I purchased this car, get it checked and then I find out the head gasket is blown and the frame is bent among other things.. But these seem to be the main issues. I hear head gaskets are expensive to repair and a cracked frame renders the car unsuitable to certification? Any ideas what the heck I can do? Should I attempt to fix the head gasket and try my best to get the frame good as possible, or try to sell the car to somebody. I spent 1 thousand on this car and I'm hoping I can get at least some of my money back if possible. As a last resort... I can always sell her off for parts and make some cash back. Ideas? Fix or sell? Any help would be GREATLTY appreciated!
hgallegos915
where exactly is the frame bent at? if u didnt get it for much you can part it
-hec
MeNtAlPaTiEnT
MeNtAlPaTiEnT
hgallegos915
If the roof frame is damaged it should be fixable.. its the kmiddle frame you dont want to bent.. even the front frame is fixable but expensive. Any pics? If u part it .. post it here. Alot of us are looking for spare parts.
-hec
MeNtAlPaTiEnT
MeNtAlPaTiEnT
Juans_93_MX3
Is it a manual?
How much mileage?
If you choose to part it out you can actually make some bank cause you will find people like me that are in need of swap parts you know...
How much mileage?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
MeNtAlPaTiEnT
Juans_93_MX3
I will bid on the front lip!
All I need is some of the swap parts from your MX3 except for the tranny
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
